Allowing a user to see the data in every project
On a rapidstart environment, I'm making tests on the engineering order workflow.
I have an ACL disallowing people who aren't in a specific project to see the data associated to that project.
My goal would be in that workflow to temporarily allow a user to see the data in every project. (For an impact analysis)
How could I succed in making this ?
Thank you in advance,
Sènan
Re: Allowing a user to see the data in every project
You can add an acl in the workflow for the accessor Is Program Member (false) and give to the world read permissions.
I hope this helps you.
Armando
Hello Armando,
Thank you for your answer, I will try it.
But before doing so, do you know if this will allow other users, who aren't in the project or the user who has to be allowed exceptionnally to read and access the data ?
I don't wan't this to happen.
Thank you in advance.
Sènan
After trying, I'm unable to see the data in the project.
Do you have any other ideas ?
