An error occurred while calling an FCC Proxy function ?
Hello
When opening NX 9.0.3.4 assembly file from Teamcenter 10. An error pops up at NX's start up:
"An error occurred while calling an FCC Proxy function"
  • I can click OK and continue normally but the message always appears on this assembly's start up.
  • What is wrong in this assembly ?
  • 57324/A and 57328/A are parts inside the assembly. Should I try to replace them ? Assembly is imported to Teamcenter but other imported assemblies work fine.
Re: An error occurred while calling an FCC Proxy function ?
I opened those 2pc parts seperately and clicked "Save" on each.
- Now the error is disappeared from the main assembly.
