Areas where teamcenter can be implemented
Can i get a list of all areas across industries where we can find a scope to implement teamcenter effectively.
Re: Areas where teamcenter can be implemented
You can refer 'Teamcenter Overview Brochure' and 'Teamcenter Feature Checklist' under Resources https://www.plm.automation.siemens.com/en_us/products/teamcenter/index.shtml
You can look up the areas (across industries) from PLM capability heat maps. They are usually available online.
Those PLM capabilities will help you narrow down on the prominent areas where Teamcenter can be applied.
Teamcenter like all PLM vendors have features (solution features) to address most of the PLM capabilities.
Harish
