Arraigning variant options in order
How to set options in serial order? I have attached pic, I have created options 6, 7, 8, 9, 10, 11 while applying variant rule options are showing up like 10, 11, 6, 7, 8, 9. They are not sequential as I created any suggestion on this?
Re: Arraigning variant options in order
As you can see in the image you attached, the variants are being sorted numerically. You'll need to prepend variants 6,7,8,9 with a zero. e.g. 06,07,08,09 for them to sort correctly.
Evaluating: AW 3.4
It works...however when i modified existing option allowed values and
modified option are not appearing
Yes, you will most likely need to rebuild the existing variants to use the new naming scheme.
Evaluating: AW 3.4
It was appearing in serial order since last week. However its not in order now.
