Assemblies that contains components as reference only in NX managed by TC
How can I see if a revision contains componentes as "reference only" in NX managed and what components are? Thanks
Re: Assemblies that contains components as reference only in NX managed by TC
Hi @Javiduc,
If you configure the column 'Info' in the ASN, it will show icon for every component that is a reference only.compref.png
Thank you Ganesh! I would like to know how to do the same in TC enviroment for workmates that doesnt have NX.
If it can be seen then it has to be in structure manager. As far as I know, there is no option or preference for it. If components are made 'reference only' from managed NX then they will not be visible in structure manager. You have to toggle off reference only option so that they can be seen in structure manager.
