Attribute Access
Hi All
Is there a way I can restrict a particular attribute on a business object to be editable only by certain roles while the object is in work. other attributes would be editabe by any role in
PLM Sprint
Re: Attribute Access
You can create a new stylesheet for this role with the attribute available for modification and the preference that control the stylesheet assigned to the group, I don't have clear if is possible to restrict to the role level, but you can try.
I hope this helps you.
Armando
You can achieve this by putting the properties on a form and compounding them to the revision. Then, create a ACL which grants access to that group for that form.
I can dig out an example if required.
Richard Bennett
Richard Bennett
PLM Consultant
www.ProspectPLM.co.uk
