Attribute Mapping From Teamcenter to NX Lowercase to all Caps
We have all of our Usernames in NX stored as lowercase.
We want to be filling out our title block with the teamcenter 'created by" attribute.
When we mapp this to NX the text comes in as all lower case.
Is there a way in NX or in The teamcenter mapping we can force this attribute to come in as all upper case in NX?
Re: Attribute Mapping From Teamcenter to NX Lowercase to all Caps
Have you tried wrapping the attribute in a regular expression (regexp) with the \U switch to uppercase the value?
Evaluating:AW 3.2
 Do I just need to use the \U in the mapping file?
Would you please give me a example tidbit on how this syntax would be formated?
We are new to this attribute mapping trying to get this all figured out.  Thanks
You won't be able to change the value directly in the mapping. It will have to be changed at the point of usage, in the Title Block. You can either try to format the cell for uppercase or wrap the part attribute with the regexp \U for uppercase. I'll try and find a specific example and get back to you.
Evaluating:AW 3.2
Ahah ok thanks.  That would be great and really appreciated.  Thanks for the help on this issue.
Looks like once you have the part attribute in the text editor then you can write an expression to wrap to part attribute. StringUpper($PART_ATTRIBUTE). Ref: https://docs.plm.automation.siemens.com/tdoc/nx/11/nx_help#uid:xid1128417:index_modeling:expressions...
Evaluating:AW 3.2
HA ha That worked.  I missed the expression part, we were trying to do it in the cell it self.
Thanks for the help.!!!
