Attribute based protection in Access Manager
Hi experts,
I am trying to provide access to custom objects using custom property defined on object. And I am  using Has Attribute key in Access Manager.
Usage:  Has Attribute(Custom_ObjectRev:Custom_Prop=value)
(as per documentation)
But this thing is not working. Please help me out.
Re: Attribute based protection in Access Manager
Attribute level ACL's? I know we've been asking for it for a while now. Are you sure that's what the documentation states? Can you provide a reference and your Tc version?
Can you please provide a snapshot of where this attribute is defined in BMIDE? Please check if the attribute is defined in te Rev or master forms?
