Automatic property assigment in BMIDE
I would like to define an automated ID generation rule for tc items. During creation of a (new) customized item in tc, the user is requested to define two item properties by choosing certain values from given LOVs - easy so far. Depending on the user´s choices, I want two other properties to be automatically set.
Any ideas / hints?
Thanks a lot for your time and support in advance!
Re: Automatic property assigment in BMIDE
Use cascading LOV's and tie the subLOVs to the properties.
Arden Bedell | Teamcenter Wonk | Applied CAx, LLC
