Autonomy fails to Index
Hello all,
Any help here would appreciated.
Having problem indexing the instances.The command shell shows the error that "Could not retrieve indexed instances".
The following error appears in the FTS log. No idea what does it mean.
IDOL error: "IDOLPROXYLIST-2147483388" - "Can't open file specified by in parameter FILENAME for writing" "" ( "ERRORPERMISSION" )
