BMIDE Template deployment error
Builder
Builder
Hello Team,
 Am trying to install customized Template copied from existing server and tried to install in TC10 of new upgrading Server, its failing with below attached pic. and below is the error message am getting.
How to resolve the issue.
The following templates are going to be installed
mmiacdcust
Install script for mmiacdcust is C:\Siemens\Teamcenter10\install\mmiacdcust\install_mmiacdcust.default
The script C:\Siemens\Teamcenter10\install\mmiacdcust\install_mmiacdcust.default has no sections
Install end time: Fri Apr 19 04:40:34 AM 2019
Install duration: 4.078 seconds
command_exit=1
Exit Status 1, elapsed time 0:00:06
An error occurred during execution. Stack trace follows...
com.teamcenter.install.tem.tasks.ExecTask.executeCmd(ExecTask.java:99)
com.teamcenter.install.tem.tasks.ExecTask.execute(ExecTask.java:67)
com.teamcenter.install.tceng.struct.tasks.TcexecTask.execute(TcexecTask.java:38)
com.teamcenter.install.tem.tasks.Task.execute(Task.java:115)
com.teamcenter.install.tem.tasks.blocks.CodeBlock.execute(CodeBlock.java:201)
com.teamcenter.install.tem.tasks.blocks.CodeBlock.execute(CodeBlock.java:181)
com.teamcenter.install.tem.struct.TcProcess.runProc(TcProcess.java:390)
com.teamcenter.install.tem.struct.TcProcess.runAll(TcProcess.java:308)
com.teamcenter.install.tem.struct.TcFeature.process(TcFeature.java:1084)
com.teamcenter.install.tem.struct.TcFeature.process(TcFeature.java:1035)
com.teamcenter.install.tem.struct.TcFeature.process(TcFeature.java:949)
com.teamcenter.install.tem.struct.TcFeature.install(TcFeature.java:874)
com.teamcenter.install.tem.director.actions.InstallAction.execute(InstallAction.java:29)
com.teamcenter.install.tem.director.DirectorScript.execute(DirectorScript.java:120)
com.teamcenter.install.tem.director.Director.run(Director.java:124)
java.lang.Thread.run(Thread.java:748)
Sameer Kulkarni
