BOM Markup
Issues using markup:
1. When adding item to the bom markup you can not edit any field of the new item , like quantity (if unit of measure is not each), find number or comment . So we need to use 2 iterations in order to get the new part added correctly. First iteration will be applied with wrong data like quantity.
2. How to export the markup as a report that summarize all changes made . This is needed as reference document fot the ECO and as audit trail to verify the changes.
Yaron
