BOM Structure export with Variants
We have a BOM Structure with Variants and options defined in it . We need to export the BOM structure with V&O and import into new environment? I checked PLMXML export and import, Only the structure is getting exported but not the rules, variant options.
Is there any way to acheive it?
Re: BOM Structure export with Variants
I thought that the OOTB ConfiguredDataExportDefault is doing it with these two lines:
2016-12-30 10_54_37-PLM XML_TC XML Export Import Administration - Teamcenter 11.png
I added this line and was able to export it for my set-up:
2016-12-30 11_00_28-PLM XML_TC XML Export Import Administration - Teamcenter 11.png
xtof
HI,
Thanks for the response.is there a way to extract the options also defined on the structure?. We have modlar variants defined on the same BOM.
