Bom Comparison report, Extract in excel
Hi, I know how to use the structure manager's tool to compare two bom. What I'm wandering is if there is a way to extract in in exacel?
I not do you think it is possible to develot some sort of tool that can query the bom comparison informations?
Thanks and regards
Davide
Re: Bom Comparison report, Extract in excel
Good Afternoon DavideEreno, maybe this is help you - try to copy selected report data and paste it into Excel:
(Note: before copy selected data, select all data using Ctrl+A)
EXCELent,
 Also, by right-clicking on the Item Id column  (not the row) of the report the menu  also offers the print option. Once selected, it allows you to create an HTML report containing a table. The resulting html file can be opened from Excel directly.
