Bulk dataset upload to items
Hi all,
I have a requirement to upload bulk datasets  to item revisions.
For bulk item creations i am using ps_upload utility. can we enhance this utitlity for datasets too
is there any OOTB utitlity to do this.
if not please suggest me how can do this
Thanks in advance
4 REPLIES 4
Re: Bulk dataset upload to items
Have a look at the following link:
https://community.plm.automation.siemens.com/t5/Teamcenter-Users-Forum/Utility-for-installing-Styles...
The accepted solution shows how to use import_file to import files in bulk mode.
HTH,
xtof
hi,
I am confused.
in the above one, they are talking about completely about stylesheets.
But my requirement is to attach datasets in bulk mode to items.
import_file utility allows you to attach dataset to the item revision. the arguments to be used are: itemRevUid and relationType.
You can specify dataset type using -type argument.
Harish
Thanks a lot guys.
it worked.
