Business object "create" dialog box
I am new to ITK customization and this is my first post . When creating a new item the Business Object Constant "Fnd0EnableSubmitToWorkflow" is set to true, so in the item creation dialog box I can select a workflow to submit the new item to by selecting a value in the Template List.
In the ITK I have added a post extention on the WorkspaceObject createPost operation and I want to read the selected value in the Template List. Can anyone guide me on the how to get the required information from the createPost operation?
Re: Business object "create" dialog box
Dear Dev,
As the workflow selection information is read and processed on the TC client post item creation using java event handlers in RAC, I dont believe this information is available in the createPost operation message or item create input.
You can use EPM_ask_workflow_templates ITK call to get a list of all the assigned templates.
Mahendra
Dear Mahendra,
thank you for the information.
