CATIA_savemanager_map_ir_object_name not working as expected
Teamcenter V9.1.3.2
TCIC V10.0.5.1
CATIA V5 R26
Problem with TCIC preference
It is set to a custom value
When they create part,
name is not populating automatically....
 CATIA_savemanager_map_ir_item_id : DANA PART NUMBER
CATIA_savemanager_map_ir_item_revision_id  : DANA REVISION
CATIA_savemanager_map_ir_object_desc : C3PNG_ItemName
CATIA_savemanager_map_ir_object_name : C3PNG_ItemName
Re: CATIA_savemanager_map_ir_object_name not working as expected
I havent used Catia, but I did search GTAC...
no idea what "nomenclature" means, but a post suggested:
CATIA_savemanager_map_ir_object_name = nomenclature
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&q=TcIC+CATIA_savemanage...
Richard
Richard Bennett
PLM Consultant
www.ProspectPLM.co.uk
Thank you for your suggestion.
but this solution I have tried erlier, This didn't worked..
Many Thanks
Mallikarjun
