Call ITK function using External SOA Application?
Is it possible to call ITK function from External SOA application?
I know in RAC it will be called through TCUserservice API
Re: Call ITK function using External SOA Application?
Hello folks,
Had a discussion with GTAC & they told that, there is no option to call ITK directly but you can create your own SOA service that wrappers ITK APIs and call that service from your external SOA application
Thank you
Hi Ravi,
Can you post some example of this ITK API connection.
