Cannot save precise assembly after adding component NX10
After adding component to precise assembly I cannot save it. I got error message.
Re: Cannot save precise assembly after adding component NX10
What did the error state? Can you upload a screenshot?
Regards, Ben
I have Russian NX. Can I switch language to get error message on English? Or maybe I will try to translate it.
You could try setting UGII_LANG=english, or just translate the error.
Error of saving
In process of saving (xxx.xx.xx/A-part_name)
- in process of saving structure data of Teamcenter product: set, waiting
OK
Sorry, but that only helps a little bit - it's the 'set, waiting' that does not relate to any similar known errors. It appears to be a problem with saving the 'structure' to Teamcenter. Is the BVR of the precise assembly checked out or locked by another process or user? Is only one assembly affected or can you reproduce this issue with all precise assemblies?
This assembly isn't locked. If I switch to imprecise, I can add components and save this assembly.
Ok, so if you can save as imprecise it sounds like you have write access to the BVR, which was my concern.  You didn't answer if the problem is specific only to this assembly.  There's a possibility that there's still an issue with the BVR itself.  I take it that switching back to precise does not allow NX to save a newly added component.  Can you add a component to the structure and save as precise using Structure Manager?
I have this problem with all assemblies.
I didn't try to add component in structure manager. I will try it tomorrow.
I cannot add component in structure manager. When I'm trying to paste it, I have error messageI.
I can paste component only to imprecise assembly.
