Change the ItemID
Hi all,
I work a long time with Solid Edge, but it used to be via Windows Explorer.
At my new job I work with Solid Edge but also with Teamcenter 10.
The project manager have given me the wrong project number which is a part of the ItemID number.
Now I want to change the ItemID of the components but I have no clue how to do that. Is there a procedure for this?
Or is it just not possible and I have to 'Save As'  via the Structure Editor?
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
回复: Change the ItemID
Hi Daniël Schuiling
You can follow these steps:
choose item-->right chick-->edit properties
choose "all" page
find id
change the itemid now
at last chick the "save and check in" button
Re: Change the ItemID
Siemens Genius Siemens Genius
Siemens Genius
Hi!
you can change item_id, click on item (not item revision!) right button of mouse and choose Edit Properties, in openned window click on All (bottom line) scrool screen and you can found ItemID attribute - change it)
All the best, Alexey.
Thanks, this helps me a lot
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
