ClientRequestException: VOLUME_FILE_NOT_FOUND_4 at login to TC
Any idea this error? FMS_HOME is correct. Able to start FCC by running tccs.bat.
For other users it is working.
WARN : 11:22:49,394 - FCCDelegate.setFccEnabled:?
FCC Interface initialized in 3 ms.
ERROR: 11:22:51,040 - TCLoginJob.run:?
ClientRequestException: VOLUME_FILE_NOT_FOUND_4 0000000000004cc3000087eb8a3b6a8d,01030000000c8a3b6a8d,dba_5576d2f5\081f000_unk_4eg05s06mc7ld.bin,{4},{5},{6},{7} (Localization not found for TextID 'ClientRequestException: VOLUME_FILE_NOT_FOUND_4' in package: 'com.teamcenter.fms.clientcache'): ClientRequestException: VOLUME_FILE_NOT_FOUND_4 0000000000004cc3000087eb8a3b6a8d,01030000000c8a3b6a8d,dba_5576d2f5\081f000_unk_4eg05s06mc7ld.bin,{4},{5},{6},{7} (Localization not found for TextID 'ClientRequestException: VOLUME_FILE_NOT_FOUND_4' in package: 'com.teamcenter.fms.clientcache')
File Client Cache is not enabled. Please contact your System Administrator.
at com.teamcenter.rac.kernel.FCCDelegate.DownLoadFilesFromPLM(Unknown Source)
at com.teamcenter.rac.kernel.FmsFileCacheProxy.DownLoadFilesFromPLM(Unknown Source)
at com.teamcenter.rac.kernel.SharedClientCache$IC_ProcessClientCacheData.refreshInstallWithProgress(Unknown Source)
at com.teamcenter.rac.kernel.SharedClientCache$IC_ProcessClientCacheData.access$1(Unknown Source)
at com.teamcenter.rac.kernel.SharedClientCache$IC_ProcessClientCacheData$1.run(Unknown Source)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Caused by: com.teamcenter.fms.util.FMSException: ClientRequestException: VOLUME_FILE_NOT_FOUND_4 0000000000004cc3000087eb8a3b6a8d,01030000000c8a3b6a8d,dba_5576d2f5\081f000_unk_4eg05s06mc7ld.bin,{4},{5},{6},{7} (Localization not found for TextID 'ClientRequestException: VOLUME_FILE_NOT_FOUND_4' in package: 'com.teamcenter.fms.clientcache')
at com.teamcenter.fms.clientcache.proxy.FileCacheProxy.generateFMSException(FileCacheProxy.java:967)
at com.teamcenter.fms.clientcache.proxy.FileCacheProxy.generateFMSException(FileCacheProxy.java:939)
at com.teamcenter.fms.clientcache.proxy.FileCacheProxy.DownloadFilesFromPLM(FileCacheProxy.java:653)
... 6 more
3 REPLIES 3
Re: ClientRequestException: VOLUME_FILE_NOT_FOUND_4 at login to TC
Have you checked if the file 081f000_unk_4eg05s06mc7ld.bin exists in volume? If it exits have a look at the access rights.
xtof
Thanks, Yes access rights was the issue.
Working now
Thanks, access rights was the issue..working now
