Comparing a drawing with its revision in Life cycle viewer of TCE
Trying to compare the latest revision with old revsion drawing of same part in Teamcenter Visview. Turned on save CGM data in both datasets while saving the file. While drag and dropping the drawing dataset its showing error "Invalid objects" Let me know for any solution
4 REPLIES 4
Re: Comparing a drawing with its revision in Life cycle viewer of TCE
Looks like you are trying open a UGPART in visualization. You will have to export the CGM file from the native NX and open the CGM in visualization and perform 2D Compare.
Hope this helps !
Teamcenter 10.1.7
TC Visualization 10.1.7
NX:11.02 | NX 9.02 | Catia V5 R2012 | AutoCAD 2018 | In-Context Editor |
How to CGM file in to the Teamcneter under item revision? after exporting CGM to native I tried to import file by selecting direct model its failed to import.
You need to have dataset type defined to import the CGM into Teamcenter and also define the viewer type to display in Visualization.
Teamcenter 10.1.7
Ok I got it, Can I link to drawing dataset to CGM dataset such that whenever changes made in drawing dataset it should get updated in CGM. Currently Both are not associateve.
