Create BoM using Excel Import to Teamcenter 10 problem
I'm trying to import Bom to TC10 using excel 2010.
So I create first the  Data Sheet and then the  Control File to do then import, and when  I start the the import process [import to team center] , no result is  shown on team center 10.
I'm wondering if someone can please tell me how to make it work
thanx
Re: Create BoM using Excel Import to Teamcenter 10 problem
Are you using Live Excel (Extensions for Microsoft Office)?
Evaluating: AW 3.4
yes
Definition of the control file (rule table) and the Transfermode/Closure Rule/Property Set are usually where problems with importing are fixed.
Evaluating: AW 3.4
Thanx ,Do you have a full example I can follow ?
Not really. I use ps_upload to create Items and structure then update the properties of the Item and ItemRevision using Live Excel. My use-case doesn't match yours.
Evaluating: AW 3.4
