Create a new menu in BMIDE
I want to create a new menu in BMIDE. How do i achieve this through Java
Re: Create a new menu in BMIDE
BMIDE is an eclipse RCP application. So you can create a custom plugin and create your menus and handlers in it.
Good afternoon, maybe you want to add a menu for the Rich Client?
BMIDE and Rich Client are built on Eclipse RCP as written by Sanjith, so it should work similarly.
https://support.industrysoftware.automation.siemens.com/docs/teamcenter/10.1/PDF/en_US/tdocExt/pdf/c...
In Client Customization Programmer's Guide go to:
Rich client customization -> Basic concepts about rich client customization -> Understanding the Eclipse rich client platform framework -> Adding menus and toolbars
For more information and full examples about how to use the Eclipse declarative approach to menus and
toolbars, see the following links:
http://wiki.eclipse.org/Menu_Contributions
http://wiki.eclipse.org/Platform_Command_Framework
http://wiki.eclipse.org/Command_Core_Expressions
http://www.vogella.com/tutorials/EclipseCommands/article.html
