Create access right in Access Manager
Can you please help what is the significance of the "Create" access right while creating ACL in Access Manager?
Mamta
Re: Create access right in Access Manager
Good afternoon, here is the description from the documentation:
Controls the creation of objects.
https://docs.plm.automation.siemens.com/tdoc/tc/11.4/help#uid:xid1256816:index_access_manager:id1997...
Suppress on Access Manager class or type by user, group, or role
Thank You Arthur!
I had already tried to use it to block create. But it did not work. So I asked here.
As described in the document, might not work for all types.
I tried to limit for myself the creation of our custom object and it works, I can not create an object:
You can not create the object because there are no required rights.
