Customize column of BOM compare
is possible to customize columns of BOM compare?
Thank you
3 REPLIES 3
Re: Customize column of BOM compare
@Andy79
I think yes, you might need to override BOMCompareReportTable class. Thanks!
Nitesh
I try to explain myself better:
I made a comparison between 2 BOM (SINGLE LEVEL)
in the report I would like a column to appear with Additional Description
Columns cannot be configured through the UI, the only way to configure the BOM Compare Report columns is through Programming.
ER# 7301282
Nitesh
