Cut & Pasting Files
Hi All.
Hopefully I can explain this correctly.  (duplicate parts with one named incorrectly)
When I search a part in teamcenter and select the part, there are three files (.prt., .dft, .pdf)
If I need to cut the .prt file from the incorrectly named part and then paste it into the part correctly named (id then updated)
The item that is incorrectly named now has two files (.dft & .pdf)
The part that is correctly named now has three files (.prt, .dft & .pdf)
All is ok, but
If I look at the incorrectly named file all three files show.
If someone else looks at the incorrectly named file only two files show .
Why is this?
