Data model failed...
During deployment there is error....FSC proxy error....
Please give solution...
Re: Data model failed...
Good afternoon, it looks like you still have problems with FSC.
1) Check that the FSC service is up and running, usually called Teamcenter FSC Service FSC_your_name
2) Check the FSC logs for errors TC_ROOT\fsc\logs\FSC\process
3) Check that the FSC is not blocked by the firewall
4) In the Organization application, check the volume settings, click the report button, it should give out something similar to the screenshot:
