Decimal Digit Issue
Teamcenter is fetching 12digits weight after decimal from solid edge. how to restrict that upto 2 digits. In our Solid edge confuguration we are using 2 digit weight after decimal.
5 REPLIES 5
Re: Decimal Digit Issue
Did you already explore "Double property formatter definition" in online help?
Try using Fnd0DoubleFormatter_2DecimalPlaces under Property Formatter in BMIDE
Thank you SRaj, Can you mention steps to add this property in BMIDE?
Please check the attachment and try once.
Siemens Creator
The Property Formatter works with RAC or is only with Active Workspace?
