Deleting files that are synchronized
I have a few files I would like to delete from the database. How do I go about doing that when the file has been synced? Maybe I am asking this th ewrong way as the error I get says : YOU CANNOT DELETE THE MASTER COPY OF A REPLICATED OBJECT.
I remember from earier version that there were steps you needed to take to get the dupicate removed and then the file would delete.  Can anyone here give me some advice on how to do this. I have delete capabilities so I know it is not permission settings.
Any help I can get for this task would be greatly appreciated
Thanks!
Re: Deleting files that are synchronized
You have to delete the repilcas at remote sites then run "datasync -f=verify -update" to remove the exports records from the master objects. Once the export records are removed then you can delete the files normally.
Evaluating: AW 3.4
Thank you, I figured I would have to have the replica delteted... . I am in NY, the database that syncs with us is in Germany. My file is the master... theirs is the replica. Is there a way to do this remotely?
Nope. You have to be logged into their database in order to search, find and delete the replica. You can instruct someone from Germany to do it or, if your company is like mine, you can RDP into the Admin workstation located in Germany to perform the task yourself. An admin will still need to run the data_sync utility against the Item to remove the export records from the master.
Evaluating: AW 3.4
Thank you.
Hello Randy,
I've deleted all the replicas at remote site.
Then beside using "datasync -f=verify -update", I have removed all export record with "?" sign that I can see from Impact Analysis. Unfortunutely, I still get an error to delete Item Revision that I want. Error massage was "You cannot delete the master copy of a replicated object"
Any other solution?
Thanks in advance
The datasync util will remove all export records. Removing the export records manually through Impact Analysis should never be necessary. That you are still getting the message is an indication that not all the export records are removed. Use the tcserver syslog to identify the object tag that is producing the error and the Print Object view to find the object from the tag.
Some companies hide objects from the users since they provide no value (unused). For instance, I've seen the Item Revision Master Form and the Item Master Form hidden many times. Make sure those are visible if you are trying to delete the export records manually.
Another possibility is that the objects in the Item tree have mixed ownership. Where most of the objects are owned locally but some of them still have the two little green dots under them indicating they are remote. In those cases you have to export the Item out to the file system and then do an export recovery to get the ownership all at your site first then remove the export records.
Evaluating: AW 3.4
