Deploy Data Model failed error in hot deployment
Reason
The difference generation(delta generation) from the data model has failed.
No update was made to the database.
It shows the deploy log file path.....
This error come while hot deployment....Please give solution.
3 REPLIES 3
Re: Deploy Data Model failed error in hot deployment
Good afternoon, can you post a log with errors?
Good afternoon, unfortunately with this screenshot it's difficult to say something without a log file
