Deploy Data Model failed
While deploying the changes from BMIDE, i am getting this error.
Deploy Data model failed
Reson: You need to be a System Administrator to be able to run this utility.
The current user doesn't have SA priviledge.
How to fix this issue and let deploy the changes well ?
Attachemnt is attached for more refercence.
9 REPLIES 9
Re: Deploy Data Model failed
Good afternoon, try to run BMIDE with administrator privileges
Yes, i have tried the same but its not working. It seems like not even getting open also.
I found that it was working previously fine but don't why it is not working now.
Which operating system are you deploying to? Linux RedHat?
Evaluating: AW 3.4
I am using Windows operating system.
Good afternoon, can you post the log file after deploy error?
There is no log file but only Windows pop up coming.
How do you connect to the TC server from BMIDE?
Which user and group?
I am using DBA group.
And good thing is i got connection successful now. Actually now i can login using another user but not mine. I don't know what happened to my login ID.
And also one thing i found that role and group values are case sensitive. That's why it didn't allow me to login.
Thanks guys to help and thanks for your time.
Windows may not care about case but Java does. My next suggestion was going to be to check the database permissions. Glad you found the problem.
Evaluating: AW 3.4
