Dispatcher -nxtocgm
Siemens Builder Siemens Builder
Siemens Builder
Hi Experts ,
we urgently need your help!!,
we are trying to get CGM and / or PDF files through dispatcher (from NX Datasets –Ugmaster and Ugpart).
Customer´s requirement is to have a CGM file updated from NX Datasets that contain 2d(drawing),I mean, they want to have a CGM file each time they save drawing (in TC working status and released status too).
Currently they have a task that send the required translations of NX Dataset modified every 30 minutes through a batch scheduled task.
On the other hand ,once the drawing has been approved ,they want a PDF file also.
The idea is that translation to dispatcher has done through a handler in Workflow for Approved Status TC.
Both translations could be done from “nxtocgmdirect” translation service in dispatcher with modifications in command line of this utility:
“export_ugdwgimages.exe”:
CGM:
"%UGII_BASE_DIR%\Ugmanager\export_ugdwgimages.exe"  -all -text=text %*
PDF:
"%UGII_BASE_DIR%\Ugmanager\export_ugdwgimages.exe" -all -text=text –pdf –nocgm  %*
Do You know any way to fulfill customer ´s requirement with the standard product (I mean without customized programm?
Is It possible to add in execution task time of translation “nxtocgmdirect” the parameters “-pdf –nocgm?
Is It possible to copy the translation service “nxtocgmdirect” to (for instance) “nxtocgmdirectpdf”?
---An alternative could be to generate the PDF file from the CGM file with a customized translation service “cgmtopdf” . Do You have any similar experience or any documented example about it?
Thanks in advanced for your help …Any idea about it will be appreciated
