DisplayValue of a LOV
Hi all ,
after some month i begin to go deeper in teamcenter soa matter.
How can i get display value of a LOV?
I can retrieve value  with LOVRestBindingStub but i  didn't found a way to obtain the list of display value of a attribute.
Thanks in advance
Re: DisplayValue of a LOV
I found the folllowing example in GTAC FAQ. It is about dynamic LOV but maybe it helps you to get the values for your set-up.
It is based on the HelloTeamcenter example that comes with the SOA libs.
package com.teamcenter.hello;
import java.util.Calendar;
import java.util.Map;
import java.util.Set;
import com.teamcenter.clientx.AppXSession;
import com.teamcenter.schemas.soa._2006_03.exceptions.ServiceException;
import com.teamcenter.services.strong.core.DataManagementService;
import com.teamcenter.services.strong.core.LOVService;
import com.teamcenter.services.strong.core.SessionService;
import com.teamcenter.services.strong.core._2011_06.LOV.LOVAttachment;
import com.teamcenter.services.strong.core._2011_06.LOV.LOVAttachmentsInput;
import com.teamcenter.services.strong.core._2011_06.LOV.LOVAttachmentsResponse;
import com.teamcenter.services.strong.core._2013_05.LOV.InitialLovData;
import com.teamcenter.services.strong.core._2013_05.LOV.LOVSearchResults;
import com.teamcenter.services.strong.core._2013_05.LOV.LOVValueRow;
import com.teamcenter.services.strong.core._2013_05.LOV.LovFilterData;
import com.teamcenter.soa.client.model.ModelObject;
import com.teamcenter.soa.client.model.ServiceData;
import com.teamcenter.soa.client.model.strong.Fnd0ListOfValuesDynamic;
import com.teamcenter.soa.client.model.strong.User;
import com.teamcenter.soa.common.ObjectPropertyPolicy;
import com.teamcenter.soa.exceptions.NotLoadedException;
public class LOV
	private DataManagementService dmService;
	private LOVService lovService;
	private final String lovUID = "DVYdH9oh4Zi2AB";
	private User user;
	private Fnd0ListOfValuesDynamic dynamicLOV;
	public LOV(User usr)
		dmService = DataManagementService.getService(AppXSession.getConnection());
		lovService = LOVService.getService(AppXSession.getConnection());
		user = usr;
		setObjectPolicy();
	public boolean loadObject()
		ServiceData sData = dmService.loadObjects(new String[]{ lovUID });
		if(sData.sizeOfPlainObjects() > 0)
			ModelObject mObj = sData.getPlainObject(0);
			if(mObj instanceof Fnd0ListOfValuesDynamic)
				dynamicLOV = (Fnd0ListOfValuesDynamic) mObj;
				return true;
		return false;
	public void listDynamicLOV()
		/* BMIDE definition of the LOV used:
		<LOVDynamic name="G4ADataset" description="" usage="Exhaustive"
		queryClause="SELECT qid FROM Dataset WHERE &quot;object_type&quot; = &quot;FullText&quot;"
       	dataType="PROP_string" queryType="Dataset"
		lovValueAttribute="object_name"
       	lovValueDescriptionAttribute="object_desc"/> */
		InitialLovData input = new InitialLovData();
		LovFilterData filter = new LovFilterData();
		filter.sortPropertyName = "object_name";
		filter.order = 0;
		filter.numberToReturn = 100;
		filter.maxResults = 100;
		input.lov = dynamicLOV;
		input.filterData = filter;
		LOVSearchResults result = lovService.getInitialLOVValues(input);
		if(!ServiceDataError(result.serviceData))
			for(LOVValueRow row : result.lovValues)
				Map<String, String[]> map = row.propDisplayValues;
				for(String key : map.keySet())
					System.out.println("UID: " + row.uid + ", key: "+ key + ", value: " + map.get(key)[0]);
	protected boolean ServiceDataError(final ServiceData data)
		if(data.sizeOfPartialErrors() > 0)
			for(int i = 0; i < data.sizeOfPartialErrors(); i++)
				for(String msg : data.getPartialError(i).getMessages())
					System.out.println(msg);
			return true;
		return false;
	protected void setObjectPolicy()
		SessionService session = SessionService.getService(AppXSession.getConnection());
		ObjectPropertyPolicy policy = new ObjectPropertyPolicy();
		policy.addType("ListOfValues", new String[]{ "lov_type", "lov_desc", "lov_name" });
		session.setObjectPropertyPolicy(policy);
