Duplicate JT files in Teamcenter 11.4 - Creo 3 integration
Anyone aware of why Teamcenter Integration for Creo (IPEM) would create multiple JT files for modifications on save.  The original file is not replaced by the new file.  Would JT config settings control this?
Any help would be appreciated.
Peter
Re: Duplicate JT files in Teamcenter 11.4 - Creo 3 integration
Check ipem.properties (eai.jtenabled = true) otherwise ipem.xml (auxiliary file map) is ignored.
Evaluating: AW 3.4
