EPM-set-property - Set value from form
can someone tell me how to access a value of a form, which is previously created during the workflow?
I'v created a form with in a task as followed:
EPM-create-form
-type MyFormType
-target_task $ROOT.$TARGET
I've showed i with:
EPM-display-form
-type MyFormType
An i try to set a property value of a ItemRevition with EPM-set-property, but how can I access a form value?
Thanks in advance
lg
Re: EPM-set-property - Set value from form
Attached is what I did recently.
Its copying a value from a form to another form, just change the include type to your custom ItemRevision.
Richard Bennett
Richard Bennett
PLM Consultant
Prospect PLM Ltd
Thanks ProspectPLM for the reply, after changing the the task parameter in EPM-create-form and EPM-display-form to $ROOT.$REFERENCE and customize your example for our object types, it works like expected. Robot Happy
lg
