Edit Common Modifiable properties
Is it possible to edit what properties are displayed or the order of the Common Properties in Common Modifiable Properties dialogue.
6 REPLIES 6
Re: Edit Common Modifiable properties
I think you can do so, by creating/adjusting the XMLRenderingStylsheet.
We just created stylesheets for the Summary and the Viewer, but as far as I know is it also possible to adjust the property view.
Thanks for the response.
I have tried to find xmlRenderingStylesheet for common modifiable properties view but unable to find any existing one.
Any pointer to this would be much helpful.
Can you share a screen shot for the properties you are looking apply a stylesheet to? Also describe how you get there...
Evaluating: AW 3.4
Need to move few properties column that are displayed in the order of the Modifiable Common Properties Dialogue
Currently dialogue looks like this:
In above snap, column's(properties) are highlighted in yellow, few more columns are at the end,
"Common Modifiable Properties" needs to be configurable to allow authorized user to view few of the properties at the first.
How to achive the this ?
I believe that dialog is built dynamically based on the objects selected and their common attributes. It is not configurable to my knowledge.
Evaluating: AW 3.4
Thanks Randy for the prompt reply 🙂
