Effectivity and revision rule
Builder
Builder
Dear all,
How should I use effectivity and
revision rule in structure managar....
Re: Effectivity and revision rule
Thats a pretty in depth topic with a lot of factors depending on your own business practices. There is some good information to get started in the product documentation for Teamcenter Structure Manager
https://docs.plm.automation.siemens.com/data_services/resources/tc/12/PDF/tdoc/en_US/pdf/getting_sta...
See sections 5 and 6 for configuration and effectivity. I believe the User training for Teamcenter also covers this in detail.
Thanks!
Gary D
Siemens Genius Siemens Genius
Siemens Genius
Keep in mind that effictivity should set on Release Status objects which will to relating with an ItemRevison in during workflow process
All the best, Alexey.
