Enter exact revision directly without step by step ?
Hello
How can I insert a revision bigger than "A" straight away like "E" ?
  • Revision box is greyed out. Why can't I insert my own revision to it ?
  • Now I have to step by step revise it like -,A,B,C,D,E...
  • I want E revision immediately to this part.
Re: Enter exact revision directly without step by step ?
Why do you want to assign revision E directly, skipping B,C,D?
TC assigns those mandatory attributes Item ID, Item revision automatically if you click Assign.
Working item revision cannot be revised unless it has released status.
This company had a different PDM-system for about 10 years.
Now it has bought Teamcenter and I input the old parts there also.
The imported old parts have now "-" revision
  • Old modified parts should be like: B,C,D or such not "-" revision.
The TC Admin can make the Item ID and Revision ID read only for the site by modifying prefs, stylesheet and BMIDE data model.
Site preferences:
  • ASSIGNED_ITEM_ID_MODIFIABLE = 0
  • ASSIGNED_ITEM_REV_MODIFIABLE = 0
ItemCreate stylesheet:
  • <property name="item_id" modifiable="false" />
  • <property name="revision:item_revision_id" modifiable="false" />
BMIDE property constant Item.item_id and ItemRevision.item_revision_id:
  • Enabled = False
  • Modifiable = Read
The above prefs, stylesheet and data model settings will result in the Item ID/Rev ID being automatically assigned and read-only.
Evaluating: AW 3.4
