Erro in check in
Hi
 I am working with plantsim and teamcenter integration.
When I duble click on plantsim model, it will be oppened correctly, but when I want to close it, I faced with attached error in teamcenter.
Can you help me to solve this error.
Best Regards
Iman
Re: Erro in check in
It looks like your plantsim software is creating a ".bak" backup file in the same directory as the model. When the model is checked in it is also trying to import the additional files, in this case the ".bak" file. You'll need to work with GTAC to exclude ".bak" file extensions when importing plantsim models on checkin.
Evaluating:AW 3.2
