Error creating new Dataset
Builder
Builder
Hi.
I have a problem on creating a new dataset. This error appears:
"Please select an item revision object to utilize this functionality"
Can anyone help me please?
Whats the reason
7 REPLIES 7
Re: Error creating new Dataset
You may have to select Item revision to paste the newly created Dataset. Can you paste screenshot, for the object in which you are creating new dataset, and the error.
Swapnil Gawas
Testing, Teamcenter 11.2.x | Active Workspace 3.x
Builder
Builder
Actually i use to open "My teamcenter" and then selecting the File menu >new Dataset.
Considering, User Home Folder is selected in My Teamcenter & you are trying to create new Dataset in Home Folder.
From the error text, it seems your Organization has allowed datasets to be associated only with Item revision.
Have you tried creating new dataset under an Item revision?
Swapnil Gawas
Builder
Builder
Thanks.
I don't know which item should be selected or created, It's a fresh newly installed TC and nothing add yet.
I just want to create a new UGPART throw dataset.
If you are allowed to create items in Teamcenter, then you can create new items using File -> New -> Item Or [Ctrl T].
Select the appropriate Item for which you want to associate UG Part from New Item Dialog box.
Or you can select any of the known item and try adding dataset to it.
After Creating the Item -> Select the Item revision -> Create Dataset.
Good Luck !!
* Corrected response
Thank you @xplm2005
Swapnil Gawas
Small correction @Swapnil_Gawas: Select any appropriate "ItemRevision" for which you can associate UG Part.
@sma wrote:
Thanks.
Create part(item) from manged NX that will get saved to the TC. If yo do so, you don't need to create item first and then add UGPART/UGMASTER dataset under item revision in Teamcenter.
