Error on web server
When I try to open a web server (by client or localhost), I get an error.
How should I do?
Best regards
Re: Error on web server
By just having the screenshot it is some kind of shot in the dark but if you can stop your webserver and delete the shared memory folder that can be found on Windows system at %temp%\v10....
Maybe this helps,
xtof
After deleting the folders you have shown me, the web server works!
Thank you so much.
Best regards
