Example how to set release status on a Dataset without workflow process Soa Api
I wanted to ask if it is possible to set a release status on a Dataset via Soa Api without using a workflow process.
If it is possible could someone give me an example.
Thank you for the help
Betreff: Example how to set release status on a Dataset without workflow process Soa Api
@kofler: Have you found a solution for setting a release status via soa api that you can share with us?
I have the same problem atm.
Thanks in advance
The reference doc for SOA C# shows :
WorkflowService.setReleaseStatus Method
Namespace: Teamcenter.Services.Strong.Workflow
Assembly: TcSoaWorkflowStrong (in TcSoaWorkflowStrong.dll)
Manages the release status status of an object The permitted operations are Append, Delete, Rename and Replace Currently Append and Delete are supported With the delete operation if an empty string is passed in instead of the status name all statuses will be cleared for that set of workspace objects.
Thanks for this hint, I will try this.
i used method posted by phenom.
