Export LOVs
Hello Everybody,
Is there any method or utility to export all of Custom LOVs? Classic LOVs?
Thx in Advance,
M
Re: Export LOVs
With a word of caution to not use the exported LOV data for import into Teamcenter, you could use any one of the below approaches:
[1] Through plmxml_export. The command would be:
plmxml_export -class=ListOfValues -u=<> -p=<> -g=<> -xml_file=C:\Temp\lov_export.xml
[2] in Teamcenter, execute 'general...' query with query name as: lov and type as 'Zip'. Look for lovData.zip to download LOV data. each LOV is an xml file in the lovData.zip, so you would need a way to merge them.
[3] You could generate a report on LOVs from BMIDE
Harish
