Export PDF to folder workflow
I am trying to export a PDF dataset that is already in TC out with a workflow.  I want to add this to the end of a release workflow.  Export the PDF to a specified folder on the network.  I need help figuring out what Hanldlers to use and how to make this happen.  I am trying to teach myself this workflow programming and am stumbling thru it.  So I am going to ask a bunch of stupid questions, so bare with me. haha.
TC10(10.1.6.1(20160515.00)) 64-bit
Re: Export PDF to folder workflow
You may be interested in EPM-run-external-command using the "-lov" argument. I like to use batch LOV's for this, especially while in development, before turning them into real LOV's in Production once they're stable. I specify one LOV using the "-lov" arg for the definition and a second LOV for the properties.
ACME4_EXTLOV_Def
• INPUT~ExportPath=E:\Exports
• INPUT~DataPath=E:\Exports
• INPUT~ExportOrigFile=YES
• INPUT~ErrorMsg1=Export failed on target %object_string% with error %$SYSTEM_ERROR%
• DATA~DATASETS=IMAN_specification~PDF
• DATA~LOV=ACME4_EXTLOV_Props
ACME4_EXTLOV_Props
• PROP:%$PROCESS.object_name%~%$PROCESS.$TARGET.object_string%~%$PROCESS.$REF.object_string%
• OBJECTSmiley SadItemRevision)
• PROP:%$TARGET.item.object_type%~%$TARGET.item.item_id%~%$TARGET.item_revision_id%~%$TARGET.object_name%~%$TARGET.object_desc%~%$TARGET.release_status_list%~%$TARGET.date_released%~%$TARGET.owning_group%~%$TARGET.owning_user%
Evaluating:AW 3.2
Ok, that is alittle above my head.  but I will give it a try.  I think all I need is the first part of that -lov  .  How do you go about writing the lov?
You define LOV's, either internal or external (batch), in BMIDE then deploy the template.
Evaluating:AW 3.2
I did presentation on this very topic at the 2009 PLM World Conference.  It's a bit dated in some areas, but the LOV portion is still valid today. You can download it at Creating PDF Files Using OOTB Tools .
Larry Carpenter, P.E.
