Export TC Impact Analysis to Excel?
Hi Folks,
is there an option, that i can export the result of an Impact Analysis to Excel? Or is this only possible with a create Report?
Re: Export TC Impact Analysis to Excel?
I can't find a way.  Only alternative I could find was the File; Print... . With the text output you could paste into excel.
Richard
www.prospectplm.co.uk
Hi Richard,
thx for your reply. I found a solution. I moved first the Details TAB to the right, so i got the impact analysis and the Details tab both beside open.
then i made the impact Analysis, selected all in the Details TAB and used that EXCEL Export. Worked for me
Genius! Something so simple yet brilliant. Nice one!
