FOP (Solid Edge + Teamcenter) - problem with relations
In our company we had a lot of FOPs. Always witch changs we revise all members and master even when we change one member or add one new member, this is ilogical. When we done this by reason relation between mambers and master looping between revisions preventing opening files.
Attached shema of a problem.
Somone have workarond this problem  ?
SE ST9 + TC 10.1.7
Re: FOP (Solid Edge + Teamcenter) - problem with relations
FOP in SE with TC is a major pain.  When revising the Master, members are still looking at the original.  User will need to do into structure editor (Similar to Revision Manager).  I would recommend when revising FOP masters is to do this with Structure Editor, instead of revising in Solid Edge.
Paul
Hello, Thanks for Your response. Exactly we use Structure Editor for this, and there are really problem with revision FOP witch attachmen in post before revision strategy (logical strategy). Actually when we want to make a FOP revision without relations modifaction we must revise FOP master and members (weste time and resources).
SE ST9 + TC 10.1.7
