FSC Cache
Hi All,
Can anyone please let me know how to confirm whether the FSC Cache is generated sucessfully or not?
Do all business objects including datasets present in it ?
Can we read them?
Background: We enabled whole file cache in FSC.xml and alloted 10GB space to it.
But we are unable to  verify whether it is generated or not.
Thanks in advance.
Re: FSC Cache
You can review TC_ROOT\fsc\FSC*.stdout for "started successfully" and it will show the cache being tested. You can also use the fscadmin util to monitor using the whole options cachesummary/whole and cachedetail/whole. Use FSC_HOME\bin\FSCWholeFileCacheUtil to purge files from the wholecache.
Evaluating: AW 3.4
