Re: Failed Install of TC Client SER2.5 On Windows 10
Will compatibility mode not work to install and run?
Windows 10 is not supported. Whatever action you take outside of support will be on your own.
Evaluating: AW 3.4
Any idea when this program will be brought up to date?
The program is specific to Ford so that's between you and Ford (or whomever gave you the package). Good luck!
Evaluating: AW 3.4
