File Client Cache is not enabled error message for a user on TC 10.1.4
Dear Community,
Hope you can help me with this issue in TC.
The bussines Object "105927XXXXX" could not be revised.
Item is not modifiable
The Current user does not have write access to the object "DR111M {Filename}"
I did delete the status of the item, but as soon as my user tries to create a new revision he receives the attached error.
- I created a new revision for him and still even with the old or the new revision and he as the current owner of the item he cannot perform revisions. Any ideas?
I really hope you can help me with this issue.
Thanks!
Re: File Client Cache is not enabled error message for a user on TC 10.1.4
In order to create a new revision, you must have write access to the item. Select the Item and view the permissions in the bottom right corner of the rich application client (RAC). For a more descriptive view use View > Access...
https://docs.plm.automation.siemens.com/tdoc/tc/10.1.4/help#uid:index_plm00125:id481456:xid429273
That should help you diagnose why the user does not have access to the Item object.
Evaluating: AW 3.4
